Viotek Monitor 32inch 1440p 144hz - Flickering (Video Inside)
Warleader165
168
Hello! So i recently bought a 1440p 144hz monitor and it seems to do a weird flickering when i set it to 144hz, when it's 120hz it's fine and acts normal, anything above that it starts up.
I've changed out the DP cable with a brand new one, still does it.
Here is a video i found on youtube: https://www.youtube.com/watch?v=ycKQ0hhJM1M
NOTE: This is not my video, it's just a video i found that seems to be doing the exact same thing mine is.
Any help is greatly appreciated!!!
It may still be the Displayport cable. It's a shame the monitor didn't come with one because they're often tested and certified.
I've had bad run-ins with DP cables because i wanted a longer cable then the standard 1m cable my 1440p 144hz (Acer XB270HU) monitor came with. This was before i found out about the large degree of improper made Displayport cables. I bought a 2m Displayport cable locally declaring HBR2 4k60Hz / 1440p 144Hz and i would get lots of flickering. Flickering at 120Hz wasn't as bad but was still flickering every couple of mins or so.
Ended up sticking with the original 1m cable, I made the distance work so left it as is.
For you, after finding about Vesa certified cables, Accell and Club3D are the leading brands.
Club3D 2m
https://www.amazon.com/Club3D-CAC-2068-DisplayPort-Cable-6-56ft/dp/B0767F5DNR/ref=sr_1_15?ie=UTF8&qid=1538189328&sr=8-15&keywords=accell+displayport
Accell 1.2m
https://www.amazon.com/Accell-UltraAV-DisplayPort-Cable-Latches/dp/B0098HVZBE/ref=sr_1_3?ie=UTF8&qid=1538189158&sr=8-3&keywords=accell+displayport
Try Club3D first.
It came with one and that's what i thought it was at first, then i bought a brand new one and it's still having the same issue :/
Yeah i've tried 3 different cables so far, all have the same effect at 144hz, 120hz is fine but i'd like to use the 144hz without the flickering :/
Could only be the cable, just a run of bad luck.
If Club3D still fails, rma the monitor.
I've read the user feedback at Amazon regarding the cable i linked and all are positive.
Whats your systems specs and brands of the other two cables you tried?
2 Insignia and then 1 that came with the monitor, the weird thing is, if i full screen a game it seems to fix it, but if i'm in windowed mode it'll flicker really bad, also when i first switch it to 144hz it'll be ok for about 5 - 10 seconds then start up, it's very strange...
You're right! didn't even see reviews for this cable, thank you for that.
Quick question, is it possible for a card itself to cause this?
My PC specs are:
Viotek GN32Q 32" 1440p 144hz
I7 8700K
GTX 1080 FTW SLI (Even with 1 card disabled or removed from PC it still flickers)
16GB DDR4
EVGA 850W G3
It's possible but i highly doubt it. Since you have two 1080s, try each card separately. I'm sure if either still flickers it's not a gpu issue but the cable, but then again coincidence is a word.
Yeah i did, both of them flicker :/
