So this is my first build. I am a noob builder with extreme emphasis on noob. I have found that most of the online guides and all the manuals have not really helped all that much. Most of what I have hooked up was just off of assumption. I have only screwed in the power supply to the case so far everything else is loose in there.
Here are some pics with some questions.
so far what ive done
these cables come from the front of the chasis, not sure where they go
does anyone know what each of these pieces are used for?
I already have my video card connected to the power supply so Im not sure what I do with these PCI E connectors. I don't even see a slot for them on the motherboard
for my hard drive, I already hooked it up to the power supply and got a sata cable going from it to the mothaboard, but theres this little 4 prong slot next to the sata connector that I don't know what to do with.
Also coming from the chasis is this grounding thing that I have no idea what to do with, doesn't seem to be any spot for it on the motherboard.
Also Im not installing an optical drive so how would I go about installing the OS via USB?
And the motherboard and vid card came with installation cd roms so I don't know what to do there.
