Question Virtual Machines storage question
Greenhadouken
9
Hi all.
My wife needs several virtual machines running at the same time, and they all need to acces the same ssd. She says that only one machen will write a part at a time in stead of them all writing to it all at once. Is there supposed to be a queue, or is there a way to make it all virtual machines acces it at the same time? I've never worked with VM before she started her P.hD program, so I dont really know how to answer her questions. The ssd in question is a intel 750 series ssd.
Any help would be appreciated.
CPU 7820x
MB gigabyte Aorus gaming 7
Memory 64gb Tridentz 3000mhz
NMVE.2 Samsung 950 pro 500gb
Intel 750 series ssd
2 tb 5400 RPM hdd
RTX 2070
EKWB supremacy custom water loop
PSU EVGA 850w gold+
You can use the same drive for numerous vm's and it will work just fine. All you have to do is set up the vm's to use the same drive one at a time. Just remember that the more vm's you have using the single drive it will slow each one down. I have two that i run on a single drive without any problems.
