VirtualBox High Sierra Problem
Jun 16, 2018
16
Dear Community,
I wanted to install a game on my macbook since I have to wait before I can get a new graphics card for my pc (the old one broke) but since the HDD is too small I wanted to install the game on an external SSD. I contacted customer support and tried a bunch, long story short --> it has to be installed on the HDD before transfering it to the SSD. So I wanted to set up a Virtual macbook on my windows pc to do that. To do so I used the following instructions: https://www.howtogeek.com/289594/how-to-install-macos-sierra-in-virtualbox-on-windows-10/
However, at the part where you have to start the virtual machine I get the following (Check screenshot)... Does someone know what the issue might be? I cant click any of the options since for some reason the mouse dissapears in the Virtual Machine and the Keyboard doesnt seem to do anything.
Thanks in advance.
https://imgur.com/R9DJWOK (screenshot)
I managed to fix it by using a premade bootdrive. No clue what the problem was. Nevertheless, this solved my issue. For others wanting to do the same this is the website I ended up using: https://saintlad.com/install-macos-high-sierra-in-virtualbox-on-windows-10/
