Thank you for your answer. At the moment (and before your answer) I've installed Virtualbox and the guest can also load the firmware of my usb device. I cannot use it yet. Maybe something is still missed in my installation.Yes of course,but only withing the guest.
Vmware still has the free version and it's much more user friendly than the other two you mention but all of them have USB support,although support in qemu sounds a bit spotty.
Regional settings maybe?Well, the device, a dvb-t one, works but the video is corrupted. No issues with file videos.
There're plenty of cheap (under $20) DVB-T USB receivers with Windows 10 support.Well, the device, a dvb-t one, works but the video is corrupted. No issues with file videos.
Yes, but I cannot buy e new one everytime I change the OS. I have that one (it isn't the only one), it works, I use it.There're plenty of cheap (under $20) DVB-T USB receivers with Windows 10 support.
