Virus/Malware need help
Cordrax
45
My computer has been infected with adware virus named unisales salesplus and unideals. i've tried every possible thing but the adware keeps on popping in my chrome browser. i tried deleting hte adware extensions disabling them, using malware bytes antimalware , adware cleaner and spybost search and destroy as well. tried deleting the associated folders and files but to no avail.
ok so first step should be to open msconfig and check under startup if theres anything by unisales.
next scan your computer with malwarebytes and doublecheck with HitmanPro
next go to regedit and search for unisales and ofc delete them usualy path are this HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Run:unisales
HKCU\Software\WOW6432NODE\Microsoft\Windows\CurrentVersion\Run:unisales
HKLM\SOFTWARE\MICROSOFT\WINDOWS\CURRENTVERSION\RUN:unisales
HKLM\SOFTWARE\WOW6432NODE\MICROSOFT\WINDOWS\CURRENTVERSION\RUN:unisales
make sure you backup your registry before changing anything there
after that go to ALL your brousers and reset them
