Vishera FX 8320 goes only up to 4GHz (Water Cooling)
McxCZ
18
Hi there ,
straight to the question.
FX 8320 Vishera goes only up to 4GHz
When I push 4,1 or 4,2 , start Prime 95, temperature goes up to 43 C* then froze crash.. (Need to manualy restart)
1.465V (I tried pushing even up to 1.5V or 1.55V) nothing
I am only playing with the Multiplier and CPU voltage, Nothing else. I'Ve read somewhere that when it goes over 65C its a problem... But I never even get close to such high temperatures.
Please any advise thank you.
OK, couple things I noticed, I have made a terrible mistake with thermal compound, at 3,7 GHz stressing about 10 mins Temperature was 62-65 C (I've putted too much). I have scraped the Thermal Compound applied it as it says on the video now I am getting after 2 minutes run 54-55 C* Temperatures at 3,7 GHz stock clock. I will bee now pushing forward so stay tuned. 😎
I'm getting stable 4,3 GHz at 75 Celsius , 1.5 Volts. If I push for 4,4 I have to raise up to 1,55 so it would stop crashing the 6th core. And the Temps goes up to 80 Celsius.
I will be buying about 2-3 120mm 2400 RPM fans I will be getting the to work together to blow more air through the radiator then I will post some info. Anyway I noticed when I start the prime95 it will start to make a little buzzing sound. And when I stop stress, the buzzing sound also stops. 😵, Anybody knows what that is ? 😀
PSU that can easily handle 3 GTX 470 plus overclocked FX. Budget doesnt really matter, but it is about 200$ or more (add 30% to U.S price of electronics to get europe prices.)
Here you go:
Power Supply: EVGA SuperNOVA 1300 G2 1300W 80+ Gold Certified Fully-Modular ATX Power Supply (£144.09 @ Dabs)
Total: £144.09
(Generated by PCPartPicker 2014-02-02 01:57 GMT+0000)
Tier 1 Brands - The Most Powerful And Stable Components On The Market.
Antec Signature
Antec High Current Pro -1200w
Antec HCP Platinum 1kW
Cooler Master V series 700, 850, 1kW
Corsair AX
Enermax Galaxy
Enermax Revolution
EVGA SuperNova G2 1000W and 1300W
Kingwin Lazer Platinum
PCP&C TurboCool
PCP&C Silencer Greater than 610 watt
Sapphire Pure
Seasonic X-Series
Seasonic S12D/M12D
Silverstone ZF (Etasis 85/75/56)
Seventeam ST Greater than 600w (SSI, V2.91)
Silverstone OP/DA Greater than 700 watt
Silverstone ZM
Ultra X3 Greater than 1000 watt
XFX Black Edition
XFX XXX Edition
Zippy/Emacs SSL
Zippy/Emacs GSM
Zippy/Emacs PSL
Zippy/Emacs HG2
Zippy/Emacs HP2
Another Question, If I buy stock coolers for my GTX 470s will it fit the GIGabyte GTX 470 and MSI ? Because, I noticed the cards that are having the original stock cooling and not the tri-fan cooler have a hole in it and maybe a different layout. Because TRi-fan cooling is great if you have only 1 card not 3 of those. Thanks.
