Hello All,
Im having a bit of an issue with Vista 64 and how it is handling the 6GBs of ram that I have installed in my PC. I been having an issue with one of my games crashing sue to no memory available for the game to continue working for some reason. It is weird because the game is pretty much the only makor application running and there are at least 5 Gigs of ram available... or so I think. The game takes about 1Gig of ram to run without any issues and it might use a bit more in some cases. What I am seeing in the Task Manager is that out of the 6GBs of ram 4GBs are CACHED with 1GB available without the game running and the rest used by the system or about 1GB used out of the 6GBs.
When I fire up the game it takes ram from the AVAILABLE pool and not from the cached pool as I would have imagined... Why is Vista 65 using 4Gigs of Cached ram for anyways? Is there a way to tell the game to use the ram in the cached portion instead of the leftover free amount of ram? Any help with this issue is appreciated. Thank You.
