W willgreenleaf Honorable Nov 2, 2013 2 0 10,510 Nov 3, 2013 #1 Windows Vista Home Premium wireless networking services appear disabled or corrupted somehow. Would like to uninstall/install the damaged/missing/disabled ones only. Is there a map somewhere of such services, their dependencies and parents.
nukemaster Titan Nov 23, 2004 19,623 6 74,965 Nov 3, 2013 #2 You should be able to remove them from the Turn Windows Features On and Off section of add remove. The Services program(services.msc) should show you dependencies. You may also wish to run a SFC /scannow as that should find files that are corrupt as well. Also note that some third party connection managers may turn off the built in connection manger from Windows. Upvote 0 Downvote
