Vista starts to load my hp printer driver then stops
Lisa_67
Hello,
I have Vista 32 bit on my laptop and have been using a compatible hp 1350 all in one printer with a usb connection. A few times it went offline, I deleted the printer, plugged it in again and it was fine.......but now Vista starts to detect it and then stops, I can't even get it to load as a printer now. What's happening?
wanamingo, I get a string of 14 choices under driver.
I have another printer installed that's working fine.
If I manually delete drivers under spool will it disable all printing functions or is this intended to clear a path so Vista will recognize the first printer?
No degrees in operating systems.
