VM constantly running at 100% CPU
kr0490
274
I have 2 VMs running on a PC with a kabby lake i7 and 16GB of ram. The 1st is running CentOS for my home freePBX. The second is running windows 10 64 bit. The windows VM is always running at 100% CPU utilization, and sometimes the disk also shows 100% cpu, but not always. The host does not have CPU maxed out. I cannot figure out what is causing this. I have reinstalled the VM from scratch several times with the same results. Any ideas?
yeah this really makes no sense to me. At this point, for me at least, I'd probably be considering redoing the whole ESXi installation just so I could start over from a clean default platform. But I really don't think the problem is coming from ESXi itself but from some setting we are skipping over or have misinterpreted and plugged in wrong.
Have you tried slapping the side of the computer and shouting "work, d@#m you!"
Have you tried spinning up a fresh VM W10? I'm wondering if its something with just this particular VM. You can also try throwing more resources at it just to see if it behaves better with them or not.
I have a VM of W10 myself. I never have any real problem with it, but I don't use it extensively. Though I do recall it runs, but slowly, with just the two core minimum.
I have erased and recreated the vm multiple times with the same result, even thrown extra memory at it and no change 🙁
when you check the CPU usage is the W10 VM actually using all the MHz it should have available to it? I'm seeing some google results of people saying they see 100% guest CPU usuage but only 20% Host CPU usage and the guest seems to max out on only a fraction of the total MHz speed it should have available to it.
The host isn't anywhere near maxing out, even though the vm is.
Hrm so I wouldn't be surprised if the vm is maxing out at some artificially low MHz then. Which would explain the poor performance and 100% CPU usage even though the Host itself says their is plenty of power available.
I'm not really sure though. Frankly the threads I find aren't orbiting a singular cause so the answers aren't all the same, or even really answers.
I think this thread is kind of interesting as it talks alot about how the cores of a CPU should be setup and assigned in the host. Since your problem presents itself even in fresh W10 VMs I can't imagine its W10 causing the problem. So maybe a misconfiguration on the Host side is the source. https://arstechnica.com/civis/viewtopic.php?f=21&t=1231195
What happens if you spin up a VM of say Ubuntu? Does it run poorly too?
I have freepbx running on centos on the host and it runs fine. Since I frequently see the disk maxing out too, I'm spinning up a new Windows vm on another disk to see if maybe there is a problem with the hdd
If the VM uses one core to 100% that's only 12.5% of the i7...but the one core of the i7 is still maxed out!
Also does centOS have CPU speed scaling? I know from dos for example that it always runs the core at 100% even if nothing at all is running.
https://access.redhat.com/documentation/en-US/Red_Hat_Enterprise_Linux/7/html/Power_Management_Guide/cpufreq_governors.html
I checked inside the windows vm and the os is showing 3.4ghz, and yes centos is always running
