Question Vnd filter help.
Andrew_263
76
Hey so I am currently looking for a vnd filter ( variable neutral dencity) and I dont know what one to get.
Money to me dosent matter for vnd filters.
I just want a great filter.
I am looking at the polarpro 2-5 or 6-9 filter. I am looking to do long exposure photos of waterfalls.
I have a kit 18-55mm lens and a 10-18mm f/3.6-5.6
Now the real question what would you suggest I get. The 2-5, 5-9 , or is there another filter that's just as good or better.
Thanks for any input.
Recommend to buy the Tiffen brand, because it can provides 2 to 8 stops of light control by rotating the ring. Also you don't need to buy more filters too, but you will need to buy two because the lenses you got use the different filter sizes (58mm and 67mm) unfortunately, if you will use both lenes for the waterfalls.
