Hi,
I have just recently changed ISP and simultaneously from "Cable-TV internet" to fiber. This made it impossible for me to use my old router because it did not have a WAN-port, instead it had a coaxial cable-port.
I got this new device from my new ISP, Ping Communications NPA201E (closest to datasheet I could find here). It is a "Analog Telephone Adapter". Basically it works as a router that consists of a WAN, LAN and two IP-Phone ports.
The problem is that the new device, the NPA201E, has no Wireless Network and too few LAN-ports to be useful as we need at least three LAN ports in this household (and Wireless). I looked around the internet for different router options and I really like the Asus RT-N65U one. However this router does not have a VoIP port.
Now for my question. If I were to buy the Asus RT-N65U, is it possible to connect my devices in a way where I can use the NPA201E's VoIP ports, but then use the RT-N65U as a switch + Wi-Fi access device? I'm thinking something like this:
Internet port
NPA201E --- IP-Phones
RT-N65U --- Wireless Devices (Phones, Laptops, Consoles)
LAN Devices (PCs)
So, will this networking hierarchy work, i.e. give all my devices internet access? Is there any problems that may occur? Alternately, is there any router out there that can provide:
Internet port
LAN Devices (PCs)
- ■ Wireless network
■ VoIP ports
■ 4 LAN ports
■ Support 100/100Mbps internet connection
