Hello,
I have found these memories http://www.newegg.com/Product/Product.aspx?Item=N82E16820104362 on another site for a very good price, but I would like to know whether the 1.65 voltage would get me in trouble if I would like to add more memory in the future and I wouldn't be able to find the exact model of memory.
Will I need to get the exact same model? Or should the motherboard solve these problems alone if I would use another model which has 1.5 standard voltage instead of 1.65?
This is the motherboard
http://www.gigabyte.com/products/product-page.aspx?pid=3894#ov
Should I get this set of memories? Or should I try to buy 1.5 voltage memories on default to prevent further trouble?
Thank you.
Thank you.
