A little while ago I started to get major fps drops in all games very randomly(from like 80 to 24). Obviously this annoyed me so i tried to find out why, and i have now figured out that it is due to my Athlon x4 860k dropping from ~3.7mhz to ~1.7mhz. When i in overdrive it looks as if it is happening due to the voltage dropping from 1.35V down to .9V. So what could be causing this, and how can I fix it? Thanks!
Pics attached are normal vs drops
http://
http://
Also, the voltage drops only happen when the cpu is under a high load, when it is idle it doesn't drop
http://
http://
