Voltage offset ok?
Paninaro86
13
I have my 4690k overclocked to 4.3ghz with according to CPU-Z a voltage of 1.175v.
Until recently i had been using a static voltage by just entering the desired voltage into the BIOS but have began to experiment with the Offset function.
I set the offset value to +0.075 giving a load voltage of 1.175v and idle of 0.78v and it seems very stable,no crashes.Temps never seem to exceed 50c when gaming using liquid cooling.
Does this seem reasonable?
Thank you in advance.
Excellent! I'm guessing the temps aren't much higher? You are totally in the safe zone @ 1.22v
