Voltage Question
marshcorps
27
Hi, at the end of the month I am looking to upgrade my mobo, cpu, and ram. I have settled on the following:
Kingston HyperX 8Gb DDR 3-1600 Non ECC CL9 Memory Modules 2 X 4Gb (KHX1600C98GX)
ASUS Maximus IV GENE Z Z68 Chipset LGA 1155 DDR3 Motherboard (MBMAXIMUSIVGENEZ)
Intel Core i5 2500K - 3.30GHz Quad Core, Socket 1155
I read somewhere that the i5 needs 1.5V, but when I check my RAM specs it has "Input Voltage: 1.9 V". It this an issue?
I am also looking to OC the processor. Probably just using the onboard OC tools to automatically set the timings etc. Will it adversely affect the product life of my processor based on the voltage?
I have a Coolmaster V8 CPU cooler, so I don't think there will be temp issues.
This rig needs to keep me going until Haswell comes out, that is the reason for the OC.
I have a 850W PSU, and a Geforce 470 GTX.
Thanks for any help on this.
genius4U
20
Don't worry that's normal voltage for 4GB 1600 MHz memory. I also used that one in my old i5 configuration.
I can stably tune my i5 to 4.2GHz with air cool and using till now.
No error at all. And the memory is running in XMP 1600 mode.
altowyran
19
hi friend
the ideal ram volt for sandybridge system is 1.5 volt
i think u must chang it if u wanna good oc and good comptaple compnents ang
and if u try to oc ur ram u must over ur ram volt
so the 1.5 vole is better than 1.9 at the volt and comptepility and heat temp
Similar threads
