Question Volume problem with Razer Seiren X microphone ?
hesham-majed
8
Well, at first the microphone was perfectly fine, but later down the line my cable got bent and kept disconnecting and reconnecting and it started appearing as "USB Advanced Audio Device" I replaced the cable with a new one it didn't fix it but it stopped disconnecting every few minutes, while I'd like to fix it it's not really important. The real problem is (I don't know when it started) the volume just keeps adjusting itself suddenly.
I usually have it on 65 but it suddenly drops to 42 or 22 or between those. It's just annoying having to adjust it back and it just drops down a few seconds later, I'd have to do it for a minute then it stops for a while just to occur later. I turned off "Allow applications to take exclusive control of this device" in the advanced section of the microphone properties which does nothing.
