G
Guest
Guest
Hi there,
System.
KT7 - RAID
T-bird 900 MHz
128 MB mushkin high perf rev2 222 RAM
2.1 GB Fujitsu HDD (3 yrs old)
generic voodoo1 card 4MB (3 yrs old)
s3 virge 325 4 MB (3 yrs old)
Will upgrade the video cards at a later date, to a geforce 2 GTS.
I have tried to run quake III and f22-adf and I can get through the startup screens. but when i actually go in to a game, it either goes to black screen or shows a screenful of bright blocky colours I can shut this down with using ctrl alt del and shut down the program with the task manager.
I have reinstalled my 3dfx drivers but they were already current anyway.
Have installed Directx 8 from an earlier version - no effect.
Only happens when I try to use the hardware feature on F22, which incidentally uses Glide, don't know if thats the problem. Could it be that it is incompatible in some way with a KT7 RAID?
Everything else runs great and stable - 2d stuff - that is.
Hope someone can help.
Thanks
Kevin
System.
KT7 - RAID
T-bird 900 MHz
Thanks
Kevin
