My system has been working flawlessly for about a month, then yesterday it stopped connecting to my work VPN when I plug the ethernet cable directly into the ethernet jack on the PC. It works fine when I connect over a wifi hotspot. The especially weird thing is that it also works fine if I use a USB ethernet adapter...same cable, same modem, same everything else. Also, I can access the internet just fine by hardwiring the ethernet into the ethernet jack. I just can't access my VPN.
The adapter is a j5 Create USB 3.0 Gigabit Ethernet adapter. The modem is an Archer CR700 with the router portion turned off and everything hardwired to the modem portion.
The error I get is "The network connection between your computer and the VPN server could not be established because the remote server is not responding. This could be because one of the network devices (e.g., firewalls, NAT, routers, etc.) between you computer and the remote server is not configured to allow VPN connections...)
