VPN for amazon fire stick running kodi
deejay413
89
7
10,535
I hope I'm in the right spot. I just got an amazon fire stick with kodi and I am wondering what a good VPN would be to use with it??
I am looking to access geolocked stuff as well as privacy. I do not have experience with VPNs. I currently have comcast for internet with one of their routers.
Can anyone suggest a VPN and explain how I would set this up with the fires stick or on the modem?? From the research I have done, it doesn't look like there are any VPN apps that work with fire stick.
Thank you I appreciate the help.
My apologies. Unfortunately you can't set up the vpn on the firestick so your only option would be to direct all the network traffic through a vpn on the router. This is also not possible on your router. You could find a router with this functionality, it's quite common. You would then bridge the modem to your new router, sign up for a vpn service and configure the connection on the new router.
I appreciate your help but there's no need to be condescending. This is something I have never done before and I didn't know certain routers weren't capable of using vpns. I come here first because usually people are very helpful.
I will look elsewhere for further help in choosing a router that fits my needs.
Thanks.
OpenVPN was supposed to work on the fire tv os3. I never got it to. Os5 is supposed to work with vpn apps but I never tried.
Look into doing it through a secondary router. You may need to dmz it on your main router. It'll be your VPN hotspot. I feel this will be a more fruitful endeavor than trying to get software to play nice and it'll be a VPN hotspot so everything will work with the VPN.
Read this guides:
https://forum.xda-developers.com/fire-tv/help/looking-to-vpn-firestick-running-kodi-t3279570
https://www.kodivpn.co/kodi-vpn/
