[SOLVED] Vsync is not working via control panel
20
4
15
Hello!
I have recently discovered that I'm unable to force vsync through nvidia control panel in gta 5. In every different game, it works but not in gta 5. I have recently updated the drivers and i'm using an rtx 2060. Could it be the games fault?? I'm using a 60hz monitor and kind of depending on vsync. The ingame vsync is not as good when you force vsync via control panel. Plz help!
I am not familiar with nvidia but check if there an override option in nvidia control panel which should be enabled. Also try different modes, from full screen, to borderless to see if it fixes the issue.
Hello!
Thank you for replying! I went and checked wich mode I was in, and apparently, if you have the game set to borderless, it can't detect your refresh rate, so when I changed to full screen, it worked!
Thank you for reminding me hehe
cheers :)
