W10 upgrade problem
MicroGuyCRO
101
Hey guys when i go to $Windows folder and run the setup i get this error: 0x80070002
(windows was unable to locate required installation file boot.wim...)
You should still get it for free. If you really can't wait you can download the setup files from here (https://www.microsoft.com/en-us/software-download/windows10). Remember to select the correct version to install (32/64 and Home/Pro), create a usb stick or iso file, and this is important, RUN THE INSTALLER FROM WITHING WINDOWS.
thanks the funny thing is right after asking this i ran the windows update search and win 10 was already downloaded and i started downloading it and it installed with no problem thanks man
