Yes this is another WOL question, but with a twist. I have an old Toshiba C55Dt laptop running centos, being used in an embedded application where it needs to be always on. The BIOS doesn't support automatic power-on, but wake-on-LAN would be fine for me. It works nicely after a shutdown as long as the AC is still connected, but in the event of a power outage, the onboard NIC no longer responds to WOL, even after AC power is restored. I'm guessing that after a shutdown on battery, power to the NIC is completely cut and it doesn't get restored until the next boot.
I thought of a loophole though. This laptop supports Toshiba Sleep and Charge, which can provide power to USB devices even when the laptop is off. It's meant for charging peripherals, as you can tell from the name. But I'm wondering if I get a USB NIC, if it could draw power this way and trigger a startup on WOL... or if it's just a lost cause.
The laptop in question is in a remote location and I'm only there about once a month, so while I'll probably have to try it to be sure, I'm interested in your thoughts before I next have the opportunity (and before buying a USB NIC that doesn't do me any good, even though they're cheap enough).
I'm also open to any other suggestions on getting this thing to turn on after a power failure!
