Wake on LAN with P4PE-X/SE and Netgear FA311
G
Guest
Guest
Archived from groups: alt.comp.periphs.mainboard.asus (More info?)
HI!
I am using a P4PE-X/SE with a Netgear FA311 network card (onboard
adapter is disabled) with Fecora Core 3. All components (board, adapter,
OS) should be capable of wake on LAN. Driver used is natsemi.
I have set the +5V jumper and enabled wake on keyboard, mouse and PCI in
the BIOS. Wake on keyboard and mouse works.
When shutting down, Fedora says "eth0 remains active for wake on lan".
ethtool reports wol enabled (ubg).
But when the computer is powered down, the light for this connection on
the router is off and that should stay on, AFAIR.
Also, it does not react on the magic wake-on frame being sent to its mac
address (tried 2 different tools for this).
I also tried under knoppix, because wol is supposed to work with that
for sure, but it does not either.
Any hints?
Thanks!
Thomas
G
Guest
Guest
HI!
Just found out, that the FA311 does not support WOL. :-((
So, I will probably buy a FA312.
Thomas
Thomas Börkel wrote:
> HI!
> Any hints?
> Thanks!
> Thomas
G
Guest
Guest
> HI!
> Any hints?
> Thanks!
> Thomas
Curious why you're using that Netgear card instead of the onboard LAN..
Robert Hancock Saskatoon, SK, Canada
To email, remove "nospam" from hancockr@nospamshaw.ca
Home Page: http://www.roberthancock.com/
G
Guest
Guest
This because the card loses power on power down. Boards with onboard
network adaptors usually don't have WOL connectors. That lead that
came with the Netgear needs to plug into something to work..
G
Guest
Guest
One of the newer PCI standards (2.2?) allows cards to continue to
receive power from the bus when the system is powered down, like for
WOL, without any power connector. That Netgear may not support this though.
