Update:
This is embarrassing. When rightklicking on the sleeping computer (see image below) , the choice "Wake up" came up.... and all problems solved...
Maybe this whole thread should be deleted, but I can't see how...
End update
Even if this case don't get solved, I assume it can be useful info here for others with remote issues?
I have chosen TeamViewer (free version) for this, and it was relativly easy to get it to work...when my desktop was running.
TeamViewer a bad choice..? Feel free to suggest something easier to set up...
When my desktop is sleeping, it seems more difficult to get it to work than getting the port/IRQ/DMA for my soundcard to work for some games, in 1991...
It is a new PC-build, running Windows 10 PRO 64.
I have put together 8 screenshots as a PDF:
http://www.bjonefoto.no/TeamViewer_Wake-Up_LAN_screenshots.pdf
Also inserted as a JPG below.
Manuals here, if you need:
ASUS Z97-A motherboard manual:
http://dlcdnet.asus.com/pub/ASUS/mb/LGA1150/Z97-A/e9060_z97-a_ug_for_web_only.pdf
TeamViewer Manual, Wake-On-LAN:
http://downloadeu2.teamviewer.com/docs/no/TeamViewer-Manual-Wake-on-LAN-no.pdf
Update:
End update
