Wall mount for controllers and headsets?
Uknowitbro
62
I cannot find any wall mounts for my xbox controllers so they are out of the way of taking up my whole desk space but still displayed on the wall for easy accessibility and showcase. I would also like to know some simple cheap wall mount rack(s) for headsets as well but the controller wall mount racks are my main concern.
Here is my setup so you may see the randomness of controllers and headsets.
https://www.instagram.com/p/9MczJRxCjH/?taken-by=gamersetups
Something like this:
http://www.homedepot.com/p/ClosetMaid-18-in-3-Tier-All-Purpose-Storage-Rack-8022/100146544
Actually there are other similar choices you can make and all the more so if you can find a product that can be easily modified (e.g., cut off the bottom shelf.) Lots of room for customization.
Just wander around in Home Depot, Lowes, Kmart, etc. and look at the shelving products. Measure out the area available for your "display", sketch a diagram, and take a tape measure with you.
