[SOLVED] Wall mount SS-CS3
They are roughly 40in high and weigh 11.5Kg. The problem is that the extended base looks like it is part of the speaker. Can than be removed? I don't know.
There isn't going to be a good way to wall mount these IMO.
I asked Sony if the base is removable. If not, i can put it on a corner wall mount shelf, what do u think?
That would be OK if you don't live in an earthquake prone area. Wall mounting will cause the tweeters to be really high. So sounds may seem unnatural because high frequency speakers are best at "ear level". If you have a screen mounted high, then maybe it won't matter.
