Want advice on a CPU+Motherboard that is compatible with my current specs
Zagoner
7
Hello! I'm looking to purchase a new CPU and Motherboard that will be compatible with my specs, but also in my budget which is most likely going to be around £300, but no higher than £400.
My current specs:
Operating System
Windows 7 Ultimate 64-bit SP1
CPU
AMD Athlon 64 X2 6000+
Windsor 90nm Technology
RAM
4.00GB Single-Channel DDR2 @ 334MHz (5-5-5-15)
Motherboard
Gigabyte Technology Co., Ltd. M52L-S3P (Socket M2)
Graphics
T24C300 (1920x1080@60Hz)
1023MB NVIDIA GeForce GTX 650 Ti (ASUStek Computer Inc)
Storage
465GB Seagate ST350041 8AS SCSI Disk Device (SATA) 35 °C
Thankyou.
^This, your system is so out of date, that you need CPU, MB, and ram. Something like this would be a solid, yet fairly inexpensive, upgrade.
CPU: Intel Core i3-4150 3.5GHz Dual-Core Processor (£77.99 @ Aria PC)
Motherboard: ASRock H97 PRO4 ATX LGA1150 Motherboard (£74.59 @ Overclockers.co.uk)
Memory: G.Skill AEGIS 8GB (2 x 4GB) DDR3-1600 Memory (£66.50 @ Amazon UK)
Total: £219.08
(Generated by PCPartPicker 2014-06-06 20:23 BST+0100)...
Total: £219.08
with i5
CPU: Intel Core i5-4460 3.2GHz Quad-Core Processor (£127.19 @ Aria PC)
Total: £268.28
(Generated by PCPartPicker 2014-06-06 20:24 BST+0100)
With i7 class performance.
CPU: Intel Xeon E3-1230 V3 3.3GHz Quad-Core Processor (£176.39 @ Aria PC)
Total: £317.48
What is your current power supply? With your budget, you could probably get a decent GPU as well, if you are concerned with gaming performance at all.
If good enough, you could go with this.
Video Card: Sapphire Radeon R9 270X 2GB Dual-X Video Card (£129.00 @ Amazon UK)
Total: £397.28
(Generated by PCPartPicker 2014-06-06 20:26 BST+0100)
I would get Logainofhades 2nd option.
Your GPU, the 650 Ti, is still a great GPU and should play games very well when paired with an Intel i5. That is well within your budget, and it is a good enough CPU that you can easily upgrade to nearly any GPU you want right now, no issues.
Hope that helps!
Seems like the best option, thankyou Logainofhades.
