want advice on cooling.
SHEKHAR SINGH
Commendable
Mar 24, 2016
6
i am looking for something which cools my laptop. my laptop is a daily use laptop but sometimes i do gaming, it heats up. is cooling pad helpful in this situation? if yes, please suggest me a budget friendly cooling pad..............
Yes cooling pads do often help, especially if the laptop isn't on a hard surface like a table when you're gaming. Coolermaster has some decent budget cooling pads. The real question is do you really need one? Unless you're getting dangerous temperatures or thermal throttling you won't really need a cooling pad.
Thank you sir, I really appreciate your suggestion.
