hi all.
I recently built/am building a new PC. Specs are:
Intel i9 9900kf
eVGA z390 dark Mobo
2x16gb G.Skill TridentZ Royal 3600mhz
eVGA RTX 2070 Super XC GAMING
Cooler Master MCM-H500M case
1tb HDD / 250gb SATA SSD / 500gb NVMe m.2
Ive replaced the rear 140mm fan with a thermaltake riing white led max 1400rpm fan
I also added 3 pccooler 120mm max 2000rpm fans to the top of the case (mounted between the glass and radiator mount bracket), and am currently using a SilverStone PF240 240mm radiator in a push/pull, with the radiator mounted under the frontmost 2 120mm outer fans, and the included SS 120mm max 2200rpm fans under the radiator, with air flow direction as intake (as well as the front 2x 200mm 800rpm fans), and the 140mm rear fan as exhaust.
I've been doing a lot of research since, and optimal cooling recommendations seem to be either mounting the radiator in the front in push/pull intake inside the case, or reversing my current top mounted radiator setup to exhaust, leaving only the 2 front-mounted 200mm fans as intakes.
I'm considering replacing the AIO with either the 360mm version, or possibly a 280mm kraken x63 or Corsair h115i pro platinum. The Silverstone PF240 does seem to have good reviews and tests, but I am new to liquid cooling (last system build was Dec 2012). Most recommendations seem to be that the 240mm radiator isn't going to cut it for my setup, which reflects in RealBench stress test, with the CPU reaching temps at a max of 91-93 before I stop it. I tweaked my fan speeds for the push/pull to try to match beat I could, setting the 2 pull fans to slightly lower rpm than the push fans (to account for resistance from the mounting bracket and the radiator itself), which seems to have helped, keeping me around 86c after 10 minutes of stress test. I haven't flipped the top from intake to exhaust yet, as I'm most likely going to swap out the radiator anyways.
So my question is, with price currently being a somewhat limiting factor (I'm trying to stay at or under $170, which is the price of the 280mm Corsair), are there any recommendations for radiator positioning front push/pull vs top exhaust push/pull, and whether I should go with a 280mm (would have to front mount that, possibly top-most so additional fresh air comes in from the bottom to get sucked up past the gpu), 360mm up top as exhaust push/pull (I could do pull-only but asthetically optimal would be push-pull rgbs like I currently use), or even front mounting a 360mm push/pull?
The 200mm front fans have low static pressure but about 90cfm. so I was looking at a 280mm with a 97cfm fan rating (I believe the Corsair h115i pro platinum?) so the pull negates the need for static pressure from the 200mm's or the Silverstone PF360 with 94cfm max. I'm not worried about running the fans at max. I just want to keep my CPU under 80c for at least a full 15m stress test, ideally staying below it for a much longer extended period of time.
The top cover on the H500M is glass with angled mesh inlets on all 4 sides. I'm using the preinstalled mesh front cover.
One additional question.. would vertically mounting my GPU offer and significant cooling improvement? the cooler master vert mount kit is around $65, which puts it at the "I'll do it if it's going to significantly help with cooling" price point, but if it's just asthetic, it can wait.
I hope I've provided enough info to get a few detailed suggestions with explanations as to why. I appreciate any and all help. Aside from replacing the cooler, I'm sticking with all other hardware. I'm not ready to do a custom loop, I want to research that much much more, I can do that some other time.
Thanks in advance.
Intel i9 9900kf
eVGA z390 dark Mobo
Thanks in advance.
