Want to build my first AMD PC, Need your help
KHADER87
129
Hi,
I've been using and building Intel & nVidia computer for 15 years and I think its time to change to AMD, the main reason is beacuse AMD products are cheaper,Mobo, CPU even GPU.
So I want your advise in building full PC from AMD product which should be better but from my current PC.
I saw some AMD product , what do you think?
http://www.amazon.com/gp/product/B00LUY72F6/ref=s9_simh_gw_p147_d0_i2?pf_rd_m=ATVPDKIKX0DER&pf_rd_s=desktop-1&pf_rd_r=1SEWA58TPBTS5BG7A316&pf_rd_t=36701&pf_rd_p=1970559082&pf_rd_i=desktop
http://www.amazon.com/gp/product/B00MUTWEM6/ref=s9_simh_gw_p147_d0_i5?pf_rd_m=ATVPDKIKX0DER&pf_rd_s=desktop-1&pf_rd_r=1SEWA58TPBTS5BG7A316&pf_rd_t=36701&pf_rd_p=1970559082&pf_rd_i=desktop
http://www.amazon.com/Sapphire-Radeon-PCI-Express-Graphics-11232-00-20G/dp/B00IU34RNU/ref=sr_1_1?ie=UTF8&qid=1425594276&sr=8-1&keywords=r7+265x
PS. I have limited budget, I need CPU, GPU and Mobo which all should be compatible.
My current PC
I3 3210
Intel DH61HO
GTS 450 1GB GDDR5
6GB of DDR3 Ram
Presuming gaming is the goal you are already off to a great start. I think you should stick with what you've got and upgrade the GPU and possibly power supply. Not going to get much better performance out of an FX 8 core in most games compared to your quite fast dual core with hyperthreading.
$400 dollar budget puts you in the GTX970 range of GPU. Might be too ambitious though for a dual core, but it would certainly give you some gaming oomph.
Another option would be a an i5 and a GTX960:
CPU: Intel Core i5-3570 3.4GHz Quad-Core Processor ($209.99 @ SuperBiiz)
Video Card: EVGA GeForce GTX 960 2GB Superclocked Video Card ($199.00 @ NCIX US)...
Total: $408.99
Generated by PCPartPicker 2015-03-05 17:42 EST-0500
If you want an AMD build for gaming, I suggest you get a more affordable motherboard and better GPU. There is no need for a "gaming" version of a motherboard if you are not overclocking the CPU and using a mid-tier GPU. You will get far better gaming performance with a 270x.
Motherboard:
http://www.amazon.com/MSI-Computer-Socket-Motherboard-970A-G43/dp/B00AQ9CF8K/ref=sr_1_1?ie=UTF8&qid=1425595652&sr=8-1&keywords=MSI+970A-G43
Video card:
http://www.amazon.com/MSI-R9-270X-DisplayPort-PCI-Express/dp/B00FR6XP6I/ref=sr_1_2?s=pc&ie=UTF8&qid=1425595238&sr=1-2&keywords=r7+280x
Thus, your original 3 products: $403.66
The new build:
AMD FX 8320E (139.99)
MSI 970A-G43 (75)
R9 270X (189.99)
Total: $404.98
