Hey folks!
So, second-time poster looking for a bit of advice on upgrading my desktop system.
I built it around January 2011 with the intention of using it as a mid-range gaming system. At the time, my main concern was playing World of Warcraft and the computer has performed admirably. I recently started looking for a laptop for my wife and in doing so have reacquired the bug for playing with hardware.
So, following the template in the stickies and without further ado:
Approximate Purchase Date: Within the next month or two. Having just bought a laptop, I'd ideally wait a bit before more expanses, but there is money available now for the right components.
Budget Range: I can spend maybe €200 - €300 at the moment plus maybe an additional €200 - €300 for each month I wait.
System Usage from Most to Least Important: Gaming, browsing the internet, Netflix/movies, listening to music, eventually photo editing.
Are you buying a monitor: No. I own a Samsung P2450H and love it.
Parts to Upgrade: Any and all. My current system is as follows:
- Asus P8P67 PRO Intel P67 Motherboard
- Intel Core i5-2500K 3.30GHz
- Asus GeForce GTX 460 1024MB GDDR5
- Corsair XMS3 4GB (2x2GB) DDR3 PC3-16000C9 2000MHz Dual-Channel Kit
- Samsung SpinPoint F3 500GB SATA-II 16MB Cache (I don't know if this is 5400rpm or 7200rpm)
- LiteOn IHAS324-32 24x DVD±RW ReWriter SATA
- Cooler Master Silent Pro Modular 700W Power Supply
- Cooler Master HAF 932 Case
I also own a Corsair A50 High-Performance CPU Cooler, though I never installed it.
Do you need to buy OS: No.
Preferred Website(s) for Parts: I like Overclockers without really having a reason for it. I'm not bound to a particular website, though - I'll take anything reliable, cheap and willing to post to Ireland!
Parts Preferences: Intel, Nvidia, Samsung, Corsair, Crucial, Cooler Master. Again, though, I'm not bound by brand - I'm more concerned about compatibility, performance and price.
Overclocking: I would love to overclock my system. It's why I bought the A50 cooler. Somehow it just never happened, but I'm absolutely up for it.
SLI or Crossfire: If my motherboard and PSU can support it, absolutely yes.
Your Monitor Resolution: 1920x1080
Additional Comments: I value quietness in my system and I'm not a fan of bling and shiny lights. My gaming focus at the moment is World of Warcraft, though I'm also keen to get into Skyrim, Diablo 3 and to have the option of playing more demanding recent titles. I mentioned an interest in photo editing, but that will wait until I've more fully realised my interest in actual photography, so isn't a major priority.
And Most Importantly, Why Are You Upgrading: I got bitten by the hardware bug while researching for my wife's laptop. I feel a need to tinker. Also, I'm finding that I occasionally get FPS problems in WoW or what feels like a system lag when I alt-tab between windows. FPS issues only last a short time and normally only after I alt-tab back into the game - it feels like the computer is maybe having to reallocate resources into the programme from elsewhere.
Edit: I should clarify that I'm looking for what would be the simplest and cheapest way to get the maximum upgrade into my system. My thoughts at the moment are that upgrading the RAM and installing an SSD will probably be my best options.
Unless I'm missing something else obvious that I could upgrade, I could really use advice specifically around those areas.
