We currently have our main router located upstairs in the central hall. This is about the most centrally located I could locate the router. The majority of our devices that are hardwired are all upstairs, so running network lines to them through the attic is fairly simple. Unfortunately our master bedroom is down stairs (on a corner of the house). As such we have historically had some occasional signal quality issues / reliability issues . I have tried signal boosters / repeaters (i.e. Linksys RE2000) but they didn't seem to improve much. I even converted one of my old routers into a repeated using dd-wrt firmware. However for reliability (especially for online gaming) I would prefer to have a wired signal. Additionally the only thing we use Coax for is our Internet, and we have Coax cables running to various rooms in the house (both upstairs and down). Which has led me initially to give Ethernet over Coax a try. I had obtained a pair of Direct TV Ethernet /Coax adapters
https://www.amazon.com/PACK-Broadband-Ethernet-Generation-Supplies/dp/B01AYMGPIO/ref=sr_1_6?s=electronics&ie=UTF8&qid=1507310395&sr=1-6&keywords=ethernet+over+coax+adapter
And have the the connection setup, and for the most part it is working beautifully. Since the product I'm using wasn't specifically designed for the purpose I'm using it for, I wanted to see if there was a better produce I should consider, and or if using a Powerline Adapter would work better. I've heard both good and bad about Powerline Adapters.
Thanks ahead of time for any info you can provide.
