I am an overclocker and have been since the days when you had to cut leads on the CPU and insulate with silcone tape. I an highly in favor of watercooling but:
The LEPA 240 destroyed my $2500 gaming laptop. It is well within the two year warranty.
I went to their site a week ago and contacted them explaining how this thing leaked all over my computer and you couldn't even tell it was leaking until it shorted out, blew up all components except cpu and memory, and burned out a breaker on the side of the house.
Damn I never got so many responses before. Please excuse my errata, no big mystery. It was my desktop, not a laptop.
They have yet to respond. I investigated a bit.
several people have reported the same problem.
I was a fool to put this in my computer. It has black hoses in a sealed system and you cannot tell if it is leaking even if you look in the case. Because it is just an intermittent drip that drys out almost immediately because of the heat of the system itself. But it did get wet enough to cause a short.
This company is Ecomaster. They own Enermax and LEPA
please do not buy any sealed water cooler with opaque hoses that does not allow you to see if the system is leaking. Aviod the heart ache I am experiencing.
I am going to ask you guys to boycott Ecomaste/Enermax/LEPA
to support the people who had their gaming systems destroyed by this type of CPU cooler.
Their crappy product destroyed my gaming computer and they don't even respond to my inquiry. Such a company should go out of business quick. Don't gamble, save your system, avoid LEPA and all sealed water coolers that have opaque hoses.
Wow, I never got so many responses to a post. Maybe I should always make a boneheaded mistake. Yes you guys are correct to question the use of a 980ti in a laptop, it was in a desktop. But that doesn't change the fact that it was destroyed by a leaking LEPA 240, or that you could not tell that the darn thing was leaking until it shorted out and put me in the dark all night, also destroying an great Antec 1000 watt PSU, and a Gigabyte gaming 7 board along with the video card. And the fact that they only responded at LEPA after I started contacting them through my email, instead of their internet site, so that I would have a record of them not responding, and then only after I threatened to take them to small claims court. Which I may yet have to do.
Please do not make the same boneheaded mistake I made: a water cooling system that you have no way to tell if it is leaking because everything is opaque and you cannot see inside is a catastrophe waiting to happen. If you or a friend notices temps rising on your system, do not continue using it. I had no such warning, but this may indicate a weeping leak at the junctions of hose and radiator. Even now though the radiator is almost dry inside, while maneuvering it around to take some photos, both places where the hoses attached became wet. It your computer has a lot of air moving around and with the heat, it can leak for sometime before it gets wet enough to short out. And you will not be about to tell because it will be dry every time you check until bang, no computer.
