Hi um just wondering what do you guys think of the h100 vs Water 2.0 Extreme
Water 2.0 Extreme http://www.newegg.com/Product/Product.aspx?Item=N82E16835106190&Tpk=Water%202.0%20Extreme
h100 http://www.newegg.com/Product/Product.aspx?Item=N82E16835181017&Tpk=h100
i'm upgrading from a evo 212 to a water cooler will there be at list 10-15C decrees from a 212 to a h100 or Water 2.0 extreme on a i7 2600k/i5 2500k .Do you guys think it will fit on a RAIDMAX AEOLUS http://www.newegg.com/Product/Product.aspx?Item=N82E16811156252&nm_mc=AFC-C8Junction&cm_mmc=AFC-C8Junction-_-Cases%20(Computer%20Cases%20-%20ATX%20Form)-_-Raidmax-_-11156252&AID=10440897&PID=3938566&SID=
i also feel like buying a new case so i wont need to upgrade in the future, any suggestion 150$ max budget and on a liquid cooler 130$ max budget.
thanks for the help.
