Water Block For asus gtx 660 oc
Zylith
7
I am looking for a waterblock that will work with my GPU. I have the ASUS GTX660-DC2O-2GD5 G-SYNC Support GeForce GTX 660 2GB -
according To http://www.coolingconfigurator.com/step1_complist -From Ek- there are no plans to make a full vga cover and I would have to use a universal one.
also XSPC says to use the gtx 680 block- but it is not listed on there supported hardware.
One is this true- Does anyone know if there is a full vga cover out there?
Two- what is the down side with going with the universal- with the obvious being that I would have to air cool the ram.
Thank you for any help you can give.
Generally, the amount of water blocks made for any particular model drops the further you get down from the top of the line, the less options available. Titan - 780 Ti - 780 all use same blocks and are widely available, 770 less so..... 760 getting scarce.
The hottest thing on a GFX PCB is the VRM.....the best waterblocks (EK) have as much as a 30C difference than the worst WB (EVGA).
See 23:00 mark https://www.youtube.com/watch?v=sDyYliSo-Hw
Rather then spend $150 on a 660 water block / backplate, I'd suggest trading up to a 770 / 780 where you will have more options.
If ya need help, let me know .... Last Build below:
Phanteks Enthoo Primo Ultimate Chassis w/ 5 x PH-F140SP_BK
Seasonic X-1250 PSU
Asus Maximus VI Formula w/ Cross Chill Water Block
Intel 4770k w/ EK Supremacy J-2 Water Block
(2 x 8GB) Muskin CAS 10 DDR3-2400
2 x SAMSUNG 840 Pro Series MZ-7PD256BW 2.5" 256GB
2 x Seagate ST2000DX001 2TB MLC/8GB 7200 RPM 64MB Cache SATA 6.0Gb/s NCQ 3.5" Desktop Solid State Hybrid Drive
Asus GTX 780 DCII w/ EK Water Block and Backplate
Mushkin Ventura Pro 64GB Flash Drive
Asus BW-12B1ST/BLK/G/AS
ASUS VG248QE Black 23" 144 Hz Monitor
Logitech G19s 920-004985
ASUS Republic of Gamers GX950 Laser Mouse
Logitech Z5500
+3 x PH-F140SP_BK_BLED
+7 x PH-F140SP_BK
Water Pump
Swiftech Dual Extreme Duty Small Form Factor 12 VDC Industrial PWM Pump - Black (MCP35X2-BK)
Swiftech MCP35x2 Dual Pump Heatsink (MCP35X2-HS)
Noiseblocker NB-BlackSilentPro PC-P 80mm x 15mm Ultra Silent PWM Fan - 2500 RPM
Reservoir
EK-MultiOption RES X3 250 - Liquid Cooling Reservoir - White Acetal (6 Total Ports) w/ (2) EK Extender Fittings
EK X3 Reservoir Multiport Replacement Top - White (EK-RES X3 - Multiport TOP WHITE)
Internal Tube 12/16 - 140mm (EK-RES-X3-TUBE-140
Radiators
Alphacool NexXxoS UT60 Full Copper Double 140mm Radiator
Alphacool NexXxoS XT45 Full Copper Triple 140mm Radiator
Radiator Size Estimator
http://www.overclock.net/t/1457426/radiator-size-estimator
Water Cooling 101
http://www.tomshardware.com/answers/id-1785226/water-cooling-101-bother.html
I'm in a similar situation. I've got the same 660 and i'm looking at ways to get some more life out of it. Can't really sell off PC parts where I live, not too many of us that build our own systems. I was clicking around the EK site and they have the EK-FC670 GTX DCII which is compatible with both the GTX 670 and 660 from Asus. I see i'm about a month late on the post but for anyone else looking in the future, the option is available.
