Hmm, not sure about that. i cant see why it wouldnt.
If your worried about it. try looking at another block or
going with a non-FC/separate cooling set up.
The Swiftech MCW60 with individual heat sinks
should work great as well.
so what you think get the FC block or Swiftech MCW60 universal? a have 210mm fan on the side, one 120mm at front and 2 80mm on the back. i need to cool 2 gtx 260 ssc and a planing for the 3rd one.
