water cooling is not quiet. However if you want the quietest system that is highly highly overclocked then sure liquid would do.
Air cooling is so much quieter because all you have are the fans running, you can get quiet fans for a inaudible computer.
However, with liquid not so much. You also have the pump which moves the liquid from radiator to block then back to radiator, they also make a good amount of noise.
