Water cooled graphic's card temp is high?
WWWouter
43
Hello,
For starters the reason why i'm bothered with this: Tommorow my new screen will arrive ( 27 inch 2k IPS 165hz+ ) and i'd love to not sit in a sauna because of the temperature coming from my pc :).
I've recently updated my build with an gtx 1080 Sea hawk x from MSI. which means i've added the card into the custom watercooled loop.
The order the water is going atm is like this:
( Not sure if this'll matter since the water should be around the same temp everywhere but well in case it does :) )
Reservoir => pump => Graphics card => Radiator => CPU => Reservoir.
While the GPU is idle in the beginning that the pc is down the temps are around 27 degrees celcius which is okay i guess.
I've played planet coaster now for about an hour - hour and a half, and the gpu seems to be around 50+ Degrees (max 54 Degrees). I know the graphics card can hold much higher temps but i've read somewhere that with water cooling you should sit at maximum high 40ies.
Below a screenshot of the temps ( game's are already off while taking this screen)
oKW2L
My liquid cooling specs are the following:
PUMP: EK-XTOP Revo Dual D5 PWM Serial pump
Coolant: EVO UV LIME GREEN EK coolant
Radiator: EK-CoolStream PE 360 ( triple )
Tubing: EK-HD PETG 12/16mm
Reservoir: EK-RES X3 250
Fans: Noctua NF-S12B Redux-700 3x on the radiator.
Not sure if this matters but PSU: Seasonic Platinum 520 Fanless
And last but not least a picture of how the loop looks
3QbBC
Is there somehting i'm doing wrong here?
Thanks in advance,
Wouter
Hi, I've just ran half an hour furmark ( int he msi afterburner program thing ). And seems like the temp goes max to 57 degrees.
Test
VIs6S
Graphs
odkoW
ambeint temperature here is now around 24 degrees.
This means i'm around 5 degrees higher then in the review. Would you suggest to change something in order to lower htis or ?
Wouter
