water cooled i5 4670k
kooks147
173
as the title would suggest I want to water cool my i5 4670k with a custom or closed loop if the performance is good for the money. My case is the Azza Hurrican 2000. If someone can shoot me water cooling setups the cheaper the better!!! Im not looking for the best set up just something that will out perform the h100i at a good cost. Even if its another closed loop! Thank you guys.
also whats the max safe temp for the cpu
idle 28-31*C, prime 95/AIDA64 load 64-68*C at that voltage. at stock voltage idle is a little less (prolly ~2* or so), load is ~8-10*C or so less.
kooks147
173
I wasnt too excited on the h80i since I owned one and was disappointed. I want to do some heavy over clocking
nagasama
63
