Hey guys, just a quick question on water cooled cpu temps.
Is it possible for my cpu temps to be lower than room temp while it is water cooled?
I have a Xspc custom water loop on my amd fx 8350 and it shows 16c-25c most the time according to cpuid hwmonitor and speccy, I've checked using other tools like occt and prime95 (not while stress testing) and shows the same thing. Room temp is around 27c usually and there are times it goes above that of course but most the time like right now, it sits at like 18c..
I don't see how it'd be possible unless the water was cooled in the reservoir or something.
