[SOLVED] Water cooler, clicking sound during desktop tasks; stops with increased load.
Apr 15, 2018
7
My water cooler produces a fast, repeating clicking sound during low processing use. When I open a webpage the sound stops during the loading phase (a few seconds). When an application is loaded the same occurs. When a processor-intensive application is running, such as a game, the sound stops.
I have stopped all the fans. I've moved (angled) the entire case. The tubes are horizontal.
Any ideas?
Thank you for helping.
Wait. What aio are you using? There's only a couple of AIO's designed for variable duty pump speeds, all other pumps should be running full speed at a dedicated 12v, non-pwm. Even the variable pumps don't operate on a curve, they are software controlled to respond to liquid temps and fan duty cycle.
