Water cooler dripping noise?
neb1006
Commendable
Mar 31, 2016
42
I recently upgraded from a hyper 212 to a coolermaster master liquid 120 CPU watercooler, and ive noticed just recently it sounds kind of like its dripping - ive opened the case up to check and i see no leaks what so ever, my temps are all normal around the 28c mark or lower when idle and around 34c when gaming. I read somewhere that it could just be air bubbles in the pump from the radiator? or could it be something worse?
neb1006
Commendable
Mar 31, 2016
42
I moved the pump cable from sys fan 4 to sysfan 1, which allows me to control the pump - having the pump run at 100% causes the popping / dripping sound, having it at 50% stops it all together. im 100% sure there is no leak, but im still slightly concerned about the noise.
Evvvvv
372
It might be a bad pump.. But it might just be noisy. Contact the OEM.
