Hey all, I recently put in a water cooler for my cpu, a masterliquid cooler, but I noticed something, I mounted the fan on the top of the case using a push pull fan setup, but just recently I noticed an awful grinding sound when the fans run full speed - I removed the top fan “pull fan” and noticed it had actually been hitting and damaging the radiator fins, my question would be “apart from replace it” should I be mounting the top “pull fan” on the radiator, or should I have the top part of my case between the radiator and fan. There should be enough room on the top of the case for clearance for a fan and the case top itself “the lid”
