Water Cooler for a NZXT Phantom PHAN-003RD
If you get the H100i, it links up to a USB port on your motherboard and you can completely customize the fan speed - and thusly how loud the fans are. It comes with the software Corsair Link that allows you to monitor everything, and modify fan speeds with different preset profiles, or you can create a custom profile, or you can just set the fans to a specific RPM.
If you want it to be virtually silent, you can do that. If you want them to be loud, you can do that too. Totally customizable, and I love it.
I replaced the fans with Corsair's SP120s (PWM). MAYBE a tiny tiny bit quieter, about the same performance, but I think they look better too. Stock fans worked just fine, and there's really no good reason to replace them.
If you want to use this case along with a cooler from NZXT, we can always supply you with L brackets that will help you mount our liquid coolers on the top of the case.
