^ Those are all atrocious prices for all of those. Wow what a terrible post.
@Belial
Iv got a water loop and I'm running a 3570k at 4.3Ghz, water-cooling is like a hobby in a hobby for me. Not just for extreme overclocking (and its good for silent rigs).
Yes, but you are buying water cooling for no rational reason. You are buying water cooling specifically because you enjoy water cooling.
OP isn't saying that, and I seriously doubt a 'noob' such as the OP just loves building water rigs.
As for silent rigs, that's preposterous. Water cooling requires fans just like air cooling, they are just as loud. And for only 4.3ghz, you could use a hyper 212+, set the stock fan to 40%, and it'd be as quiet, if not quieter, than any water cooling rig.
I wouldn't really say sound would be an issue if you are just doing 4.3ghz. If you really wanted quiet, you'd get an HR-02 Macho and not put any fans on it, that would really be the quietest, capable cooler.
I take no offense at all! I appreciate blunt honesty. As much as I would love to be able to play around and blow out parts I can not afford to blow out parts. I want a water cooler because I plan on going with 16gb of ram and I just do not feel like dealing with clearance issues of a big aftermarket heat sink, plus a water cooler, whether or not I overclock hardcore is going to be a more efficient cooling device. I am a Computer Science major and I write programs for my college (College of Engineering) so while I am spending a decent amount of money building it after that I need it to work properly.
Can you provide me some suggestions for under $100?
Thank you for your help!
Be careful because when you ask for help on line, people will recommend you spend the bank because it's not their money. You also get a lot of bad advice on forums sometimes.
There is no 'blowing out of parts'. It's like saying "I cant afford to drive my Shelby Mustang 50mph on the highway so I drive on the backroads". It's a shelby, and 50mph is not going to stress anything.
Ivy Bridge is extremely durable, and it would take a LOT to 'blow it out'. You have to understand, water cooling is for cooling extreme voltages, as in voltages that will cause an Ivy bridge to degrade. If you aren't doing that, it's just a waste of money (unless you are like manofchalk and do it for aesthetics), when a 'measly' high end cooler could do the same job for 1/4th the price.
Also, RAM fits to a standard. Going for water cooling because you are buying lots of ram is absolutely absurd. It's like saying "I fly the plane everywhere instead of take the subway because I'm afraid I'm not short enough to fit through subway doors".
It's built to a standard. Unless your RAM looks like this:
http://images17.newegg.com/is/image/newegg/20-233-144-TS?$S300W$
Trust me, you aren't going to have issues with RAM. Even with taller ram, you can fit it on most coolers because you can slide the fan up and down to be compatible with high heatsink ram.
See:
http://i.imgur.com/KzEqvl.jpg
Why are you going for 16gb of RAM? I hope you are aware that for gaming/general usage, getting more than 4gb of RAM is a waste of money because games are specifically written to be compatible with 32 bit OS, meaning you can't possibly use more than 3.5g of ram in gaming. Bear in mind that the best RAM, such as PSC and BBSE, is only made in 2gb sticks.
I'm actually a heatsink tester, I test heatsinks for companies and do official reviews. I've tested over a dozen heatsinks, and not once have I had issues with RAM compatibility, even with over half a dozen kits of RAM owned.
It's such a non-issue. If your ram is any bigger than normal g.skills or kingston hyper xs, just google your cooler + ram and see if there's an issue. It's really quite easy to do....
It's such a non-issue, that I would not worry about ram compatbility until after you pick out your ram and heatsink.
The best heatsinks right now are the Zalman LQ320 for $39 (not sure if that sale is still going on) or the Logisys Assassin, the best air heatsink in the world for only $39 at performancepcs.com. There are other coolers that are similar, on ebay used or something, but you can figure that out for yourself.
Specials come and go every day, so I'm sure tommorow there will be a better buy for the money. You just have to keep an eye out.
