Water Cooler for my system?
Tonho
I'm thinking in getting a H100 watercooler, from corsair, to cool my future system (if it fits inside my case) that will be in a not too airflow-friendly spot. I also want to know if the corsair gs700 will be an good option or should i get a different PSU.
System:
FX-8320 (not overclocking, for now)
GA-990FXA-UD5
Sapphire HD7870
8Gb ram (1x8Gb or 2x4Gb)
1x 60Gb SSD
1x HDD (500Gb or 1Tb)
Corsair gs700
Thermaltake Armor A60
I only bought the case till now, so you're welcomed to suggest any other coolers and/or components that will be cheaper/perform better for the same price.
Thanks
@ $100 price point..That cooler is about as good as it will get..
You can get creative with the RAD placement..Mount it out back with a 1-inch gap..all kinds of stuff.
I use a bong cooler though..so in-case cooling is definitely not my thing.
