I'm looking to water cool my Gigabyte GTX 1070 G1 and i5 6500 but I have never water cooled before so I'm looking for some guidance. I've only found one GPU block that works for me, but the kits I've been looking at are either very expensive or not compatible.
This is the GPU block: https://www.pccasegear.com/products/37549/ek-full-cover-vga-block-ek-fc1080-gtx-g1-nickel It's currently the only one that I've found that works but I wouldn't be opposed to using a diferent one if it would work better.
What would be the best way to water cool? Would I be better off using a kit, or just buying the components seperately and making a custom loop?
Thanks for the help
Thanks for the help
