Water Cooling a P4D
Kemikal
5
My temps with water cooling is idling @ 27-32C is that warm for water cooling? i have a Pent D 840. give me some input guys. i need to make sure this is running right. :)
i was just asking in genreal to water cooling if it was a good temp, my P4D 840 is clocked @ 3.8ghz ;x idle is @ 31-32C Via Speedfan in windows. Room temp prob 70Fs
What watercooling system? Ambient temps? Load temps are okay?
I'll steer you to some more technical links, please spend a few days (DAYS) reading posts, searching, learning. Don't forget to look for your case with WC. Google your case and the word watercool or some combination of that. WC stuff is larger than you think, I know from experience. WC setups done right are awesome and almost silent.
Great place, not wayyy over the top with uber WC guys.
http://www.ocforums.com/index.php
Uber place, owned by one of the worlds winning OC guys in the world. Not a place to post or ask questions by noobs, but an awesome place to learn.
http://www.xtremesystems.org/forums/
Another good place to learn
http://www.overclock.net/water-cooling/
http://www.martinsliquidlab.com/ PLEASE READ A LOT HERE, will be closed in 30 days or so.
Great places to buy WC stuff
http://www.dangerden.com/index.php [...] e&Itemid=1
http://www.petrastechshop.com/
http://www.jab-tech.com/
Well, right now i raised my volts a tad, and im getting 4.0ghz out of this 3.2 pent D 840. geebus. i havent seen the temp go past 50C @ the 4.0ghz clock. thats with me playing world of warcraft for over an hour in window mode so i can see speedfan <3
